Makergear M2 Dual with LCD - Experimental FW
Progwhiz
Post by Progwhiz » Wed Sep 09, 2015 2:35 pm
Hi All,
I did some tinkering with the last working Dual and LCD firmware and merged with the more stable MG Dual fw. It seems to behave well and even with S3D. I'm attaching the hex file for your easy upload.
Regards
Makergear_Dual_LCD.zip
Dual and LCD Fw
(100.02 KiB) Downloaded 860 times
Re: Makergear M2 Dual with LCD - Experimental FW
Post by insta » Sat Sep 12, 2015 4:04 am
This is a little worrying with just the .hex ... can you attach the Arduino sketch here, or somewhere like Google Drive / Dropbox?
Progwhiz
Post by Progwhiz » Thu Sep 24, 2015 8:11 pm
Hi
I am attaching my final version as it seems to have resolved all the issues I didnt like such as:
1) Simplify3d connection issues
2) Jerking
3) Axis drifting
4) Ability to reset SD card manually
5) Correct premature timeout to status screen
6) Navigate through menu items one click only required
I will post a reprap lcd version later which corrects the ability of one click turn per menu item.
Mark
Makergear_Dual_LCD_NoJerk.zip
(92.57 KiB) Downloaded 883 times
fmeroney
Post by fmeroney » Sun Sep 27, 2015 7:57 pm
Do you have the sketch available? I would rather upload via arduino and be able to tweak it for the extras on my machine.
Progwhiz wrote:Hi
2) Jerking
3) Axis drifting
Mark
jamigas
Post by jamigas » Fri Feb 05, 2016 3:26 am
Hey mr. Progwhiz, any more firmware updates worth sharing on your end for Dual with LCD? And could you tell me which LCD your previous reworks were for... Viki 1, Viki 2, or Geeetech? Much love :D
Levi8than
Post by Levi8than » Fri Feb 05, 2016 6:59 am
Can you share the source? I'd like to look through your changes and merge them with mine if possible. Thanks.
