Modified Ikea enclosure
Re: Modified Ikea enclosure
I didn't go with a fan, just leave the door open a couple of inches when printing with ABS so it does not get too hot in there. Works fine. I really like the clean look of the white cabinet with the fan on top though!
-Don
-Don
Right, but if I did use a fan, I was hoping to get some advice.dsmith wrote:I didn't go with a fan, just leave the door open a couple of inches when printing with ABS so it does not get too hot in there. Works fine. I really like the clean look of the white cabinet with the fan on top though!
-Don
Understood... Just wanted to let you know that it works without the fan if you did not get the advice you were looking for.
I did post the male and female STL files for the cable gland as well as the fan shroud, but looks like they have to be approved by the moderator before they actually show up. I find that the fan certainly makes for a better controlled temperature for larger prints - as well as it allows the door to be closed making it a bit quieter.
Thanks very much Dug.
- pyronaught
Is the box just not deep enough to place the M2 forward facing rather than sideways? Seems like it would be annoying trying to remove parts, adjust the z-stop or level the platform with the machine sitting sideways like that, but every Ikea cabinet setup I've seen has it sideways.
thunderbt3
Correct. If it was slightly deeper, it could accommodate the full travel of the Y-axis.pyronaught wrote:Is the box just not deep enough to place the M2 forward facing rather than sideways? Seems like it would be annoying trying to remove parts, adjust the z-stop or level the platform with the machine sitting sideways like that, but every Ikea cabinet setup I've seen has it sideways.
I don't find it that inconvenient with the printer sideways.... you always end up removing the build plate to remove the parts and the M2 sits biased to the right, which leaves quite a bit of space to the left side (front) to be able to bed-level and the like. I also put another door (solid) on the back side to be able to easily change out the filament. You do have to install some heavy-duty right angle corner brackets at the top (can see in my picture) because you lose the support and squareness when there is no solid back to the cabinet. Have to use push-in screw anchors for the bracket screws because of the hollow/composite nature of the cabinet construction.
- pyronaught
This is the one I built from scratch. The bottom cabinet is for filament storage and the printer section is temperature controlled. One thing I really like about this design is the slide-down door, since you can open and close it without a big door swinging open. It's only possible to do that when you have a lower section for the plexiglass to slide down into. I'm going to be making some more compact stackable boxes but won't be able to put a sliding door on those unfortunately since there will not be a cabinet under the printer. The only thing under the printer will be another printer
Wow, that is a beauty pyro......
I wish i had a basement.
