new improved filament holder with cleaning sponge
psd
Re: new improved filament holder with cleaning sponge
Post by psd » Wed May 04, 2016 12:54 am
Ill give it a shot!
- peter,
www.petersolomondesign.com
Cosmeo
Post by Cosmeo » Thu May 12, 2016 7:37 pm
Printed mine up the other day and just got the canola to put a dab on the sponge and installed, works fantastic. great design thank you.
psd
Post by psd » Thu May 12, 2016 10:09 pm
thanks Cosmeo,
nice to hear it is appreciated! I will be making one for second extruder as soon as I have a chance.
- peter,
Post by Jules » Fri May 13, 2016 3:26 am
I like the little snake on the new version too! :D
psd
Post by psd » Fri May 13, 2016 5:42 pm
:D
Jules wrote:I like the little snake on the new version too! :D
- peter,
Post by Jules » Fri May 13, 2016 6:05 pm
BTW...I did print the original - (nice tight job on the fit) - I particularly like that the clear tubes actually click in there and hold! :lol:
I'm messing with the one for the right side this morning.....(and the little snake will print the same on both...that's just good design!) :D
psd
Post by psd » Fri May 13, 2016 6:41 pm
Jules wrote:BTW...I did print the original - (nice tight job on the fit) - I particularly like that the clear tubes actually click in there and hold! :lol:
the little snake - is this the embossed logo? thats my studio logo, or is it the clasp to keep the door shut?
I will make it if you don't get around to it, had a tight deadline, should be delivered by Monday then I will make it.
Let me know!
- peter,
Post by Jules » Fri May 13, 2016 7:00 pm
The one on the flat door....cool design. :D
I've got time to play with it this morning, but if you want to do one down the road, it will likely turn out better. I'm having to re-work the STL, for some reason Rhino wouldn't recognize your Solidworks file format. Probably not doing it right, but i don't have time to mess with it.
(I hit it with the parametric converter and it turned out fine from the STL....they don't always do that on the more complicated files.)
We'll get something working for the duals. :D
Post by Jules » Sat May 14, 2016 3:05 pm
Here's a stable right side one if anyone wants it for the Dual.....It should fit in the upper right screw hole of the X-axis motor, with a little washer, using the supplied screw for the dual setups. (Gave it a small slot to allow for variances in manufacture/printing.)
Hinged Filament Guide Right.zip
(6.65 MiB) Downloaded 2939 times
psd
Post by psd » Sat May 14, 2016 7:15 pm
Looks great Jules.
as soon as I buy my dual extruder I will download and print yours!
- peter,
