Removing bed springs
Deereengineer
Has anyone successfully improved the bed leveling by removing the springs ? Cnc machines have no springs so I can't see why we need them on the m2.
thunderbt3
Re: Removing bed springs
The Rev. E machines do not have springs. The bed leveling procedure is completely different than the 3 point leveling you currently have. You would need to upgrade to the 4 point spider that solid mounts to the z platform.
Works fine for me:Deereengineer wrote:improved the bed leveling by removing the springs
https://softsolder.com/2013/05/31/maker ... ilization/
The silicone disks support the platform. I couldn't think of anywhere better to store the springs, so I left them in place.
The downside is that the platform has absolutely no vertical compliance: if the nozzle rams the glass (or aluminum or whatever) hard enough, something's gonna give.
The best result is that the Z motor slips first. Wouldn't that happen before the glass breaks, or anything else catastrophic?ednisley wrote:The downside is that the platform has absolutely no vertical compliance: if the nozzle rams the glass (or aluminum or whatever) hard enough, something's gonna give.
I vaguely recall somebody showing off a cracked glass platform from a nozzle crash (as well as one from a corner clip gotcha), presumably with springs involved. That surely required more than a casual crunch.Tim wrote: Wouldn't that happen before the glass breaks
I'd worry more about deforming the nozzle or bending the hot end, particularly on a V4. Although I know it's a durable bit of brass you folks think nothing of reaming out with wires & carbide drills, the tolerances call for careful treatment. Mashing it against the platform can't possibly be good for it.
On the other paw, I haven't had anything exciting happen for a couple of years; I definitely worry too much ...
you cant remove the springs. if you remove them then what is going to push the bed upward so that it can be adjusted?
For my M2, I used a trio of silicone rubber washers with enough compliance to level the platform, cut from scrap vibration isolators in my Pile o' Stuff:jimc wrote:what is going to push the bed upward
The washers, along with the M2 spring and mounting screw, stand along the center bottom of the picture. The junk on the top shows that it took me a while to get it right...
Anything rubbery with some flex, about that tall, should work.
The platform sits flat on the not-quite-solid washers. The adjusting screws compress the washers just enough to level the platform, after which it's pretty much a rigid part of the Z-axis machinery with no compliance at all.
The silicone washers didn't make much difference in the overall print quality, but I haven't had to align the platform in ... I don't remember.
Yes i remember you used silicone washers which is great but it sounded like the op wanted to simply just remove the springs
Deereengineer
I'm ok with keeping the springs , but I want to stiffen things up enough so that a dial indicator will read correctly without moving the build plate .
Get a rev E spider. You can keep the Z=0 homing if you want.Deereengineer wrote:I'm ok with keeping the springs , but I want to stiffen things up enough so that a dial indicator will read correctly without moving the build plate .
