Rev E spider ...moving Z switch to bottom
scampa123
Post by scampa123 » Tue Feb 06, 2018 4:38 pm
I’m currently upgrading my spider to the revE and as part of the process I have to move my Z switch to the bottom of the printer (vs top).
Question: with the new Z switch bracket (for unit with silver motor), do you pus the bracket completely down to the bottom of the rod as far as you can got? Or do you raise it slightly?
Thank you!!
Re: Rev E spider ...moving Z switch to bottom
Post by sthone » Tue Feb 06, 2018 7:24 pm
I don't know what the "new bracket" looks like but on the original ones (if I remember correctly) it had to be up off the bottom a bit for the bed actually make contact with the switch. I usually end up putting a washer or some kind of spacer under it though so it doesn't move down when the bed drops on it. If you can have it all the way at the bottom and still work I'd probably do that.
Keep in mind if you move the switch to the bottom you have to run the new firmware too.
scampa123
Post by scampa123 » Tue Feb 06, 2018 7:40 pm
I haven’t installed the new firmware yet to test, however I did notice if I pushed it to the bottom it only started to press the switch, which is why I sent this note). I’m not sure if it presses it enough to trigger when placed all the way down...that is what I was trying to determine....
I think the idea of putting something under (if it needs to be lifted) is interesting because I could see the weight of the bed making it move....
Post by insta » Tue Feb 06, 2018 8:03 pm
Either get the bracket that holds the switch, or use top-homing.
scampa123
Post by scampa123 » Tue Feb 06, 2018 8:14 pm
insta wrote:Either get the bracket that holds the switch, or use top-homing.
I do have the bracket, but am not sure if it should be pushed all the way to the bottom (it is clamped to the back rod), or if it should be lifted slightly from the bottom....
jk42
Post by jk42 » Tue Feb 06, 2018 9:35 pm
There are two mounts for the z max endstop.
For printers with the black z motor, it mounts on top of the z motor.
For silver there is a bracket that mounts to the rear guide.
Please contact us a support@makergear.com and send us a picture of what you are seeing.
We would be happy to assist you in getting up running!
~Jason from MakerGear
scampa123
Post by scampa123 » Wed Feb 07, 2018 4:08 am
jk42 wrote:There are two mounts for the z max endstop.
I will send some photos when I return from my business trip. Thank you!!
Post by insta » Wed Feb 07, 2018 6:10 pm
I run the black-motor mount on the silver motors. It requires some extremely short M3 screws, but otherwise works fine. It might also work with really long M3 screws running all the way through the motor and fastened down with a nut.
scampa123
Post by scampa123 » Thu Feb 08, 2018 3:01 pm
Here are my photos...
You can see that with the Z switch pushed all the way down the platform barely engages it when it is lowered.
I'm not sure how much you expect the switch to be triggered or how much to raise it. I don't want to put undue stress on it, but also want it to trigger correctly. Then do I need to put something under it or simply tighten the bolt....
Thanks!!
Post by insta » Thu Feb 08, 2018 4:56 pm
I just bent the lever slightly
