Printing with my new spool holder.
markb
Post by markb » Sun Oct 26, 2014 2:37 am
I just got a new 3kg 1.75 ABS but I did not have a big enough spool holder for it.
I found this one http://www.thingiverse.com/thing:119488
It is a really good design. It fits M2 without any screws. It makes this 3kg spool spin very free.
I will not have to change spools so often now.
On the first picture you can see I used two clips to keep the spool on. I am not sure that is needed but better safe than sorry.
Re: Printing with my new spool holder.
Post by jimc » Sun Oct 26, 2014 4:42 am
haha spool is massive. it looks like it will tip the m2 over on the left.
Capt. John
Post by Capt. John » Sun Oct 26, 2014 5:06 am
Nifty setup with the filament wiper, great job.
Capt. John
Manistee, Michigan
Reel Amateur at 3D printing
http://www.michiganangler.com
jdacal
Post by jdacal » Sun Oct 26, 2014 11:12 am
Were you able to print the spool holder piece without supports like the instructions mention?
jdacal
markb
Post by markb » Sun Oct 26, 2014 3:47 pm
jimc wrote:haha spool is massive. it looks like it will tip the m2 over on the left.
No fear of it tipping over M2 is much heavier. It does look big on there. This will be so much nicer not having to worry about running out so fast now.
We print alot ABS and this 3kg spool is really going to help.
markb
Post by markb » Sun Oct 26, 2014 3:49 pm
jdacal wrote:Were you able to print the spool holder piece without supports like the instructions mention?
That is a good question but I had just printed something with support before I printed this.
So I ended up printing it with support.
It is almost runs to freely I need to tighten it up a little after this print.
jdacal
Post by jdacal » Mon Oct 27, 2014 1:20 am
I'm printing it at the moment without supports, I'm kind of doubtful it will work, but had already started this earlier in the day before I read your post.
I can't believe Home Depot doesn't stock the bolts without the threads, at least my nearby one doesn't. Now I'm going to have to order them.
jdacal
Post by jimc » Mon Oct 27, 2014 1:27 am
every once in awhile i check your video feed to see what your printing. funny , next thing on my print list is about a dozen filament clips. btw nice knob and fan guards :D
jdacal
Post by jdacal » Mon Oct 27, 2014 6:03 am
jimc wrote:every once in awhile i check your video feed to see what your printing. funny , next thing on my print list is about a dozen filament clips. btw nice knob and fan guards :D
What can I say? ... Designed by one of the best! Really like both designs, thanks for sharing. Still dying to try out the E3D hotend with your parts on it, but I keep putting off making the harnesses.
jdacal
jdacal
Post by jdacal » Mon Oct 27, 2014 7:31 am
Here's the hardware I ordered from McMaster-Carr in case someone else has trouble finding the bolt without the threaded portion.
1 pack 92186A604 Type 316 Stainless Steel Hex Head Cap Screw, 5/16"-18 Thread, 5-1/2" Long
1 pack 97135A220 Grade 8 Steel Nylon-Insert Hex Locknut, Zinc-Yellow Plated, 5/16"-18 Thread Size, 1/2" Wide, 11/32"
1 pack 95630A219 PTFE Flat Washer, 9/32" Screw Size, 0.325" ID, 0.750" OD, packs of 10
The PTFE washers weren't part of the project but I'm hoping there's enough room where I can put one on each end to reduce lateral friction of the spool holder against the mount and the locking nut.
Thanks for recommending this markb, I had been doing searches for something just like this for a few weeks but that one wasn't coming up for me. I was hoping to find something similar with bearings, but from the videos it looks like there's not a lot of friction. Oh, also ordered a can of DuPont Teflon Non-Stick Dry-Film Lubricant Aerosol Spray, 10 Oz., hoping to coat the bolt with it to reduce friction even more, from Amazon.
EDIT: This is also my first time trying the Sequential printing feature in S3D. Pretty neat! Worked good so far, I set the clearance at 6mm due to the fan, but could probably go to 8-10mm after I take some time to measure it more accurately.
jdacal
