M2 Extruder stepper motor not turning
Re: M2 Extruder stepper motor not turning
do you have filament in it when your trying to turn the motor?
Ok well at this point you should contact makergear support
MakerGear support figured out the issue for me. My son had changed the extrude speed in Pronterface to 5mm/min (from 100) so it hadn't really locked up, it was just turning really really slowly!
hahahahah!!! thats a good one
its funny now but im sure it was frustrating. its good you got that resolved.
That's pretty clever. I would never have thought to check for that. I guess when you handle "real" support calls, you've seen it all....
I have twenty bucks that says Josh is the one who figured it out. He's seen everything with Pronterface.b8smat wrote:MakerGear support figured out the issue for me. My son had changed the extrude speed in Pronterface to 5mm/min (from 100) so it hadn't really locked up, it was just turning really really slowly!
Ok, was trying to change filament, extruded couple cm and when I inserted a new filament it didn want to feed, and then I figured out that extruder motor doesn't work. I took filament drive off the motor and now I'm trying to extrude or reverse and motor gear doesn't turn, when I try to turn it by hand it turns easily. I heated hot-end up so it doesn't prevent me from cold-extrusion. I did reset Rambo but still no result. What else can I do?
UPD: fan on RAMBO doesn't work either
That suggests the pinion gear on the motor shaft that drives the planetary reduction gear is loose / broken / worn out.nokianich wrote: motor gear doesn't turn, when I try to turn it by hand it turns easily
Put a mark on the motor shaft (on the back of the case) and see whether the shaft turns when you:
- Spin the filament drive gear by hand: no = bad pinion
- Extrude some filament: yes = bad pinion
Do the other motors operate correctly?
That's driven from the same MOSFET that runs the upper fan (on the filament drive). If both fans are stopped, then there's a common problem. If a wire fell out of the connector and touched the logic circuitry inside, well, that could kill pretty nearly everything.UPD: fan on RAMBO doesn't work either
it didn't work at all but it was stupid move on my side, moved the printer to change a pool and cable from power supply unplugged connector to Rambo in half. Plugged it in back and everything works now. Thank you anyway for reply
