Taulman Alloy 910 Profile?
KaiborgStudios
Post by KaiborgStudios » Wed Aug 31, 2016 9:38 pm
Just received my first spool of Taulman Allow 910. Would anyone be kind enough to share their profile?
Thank you!
quaver
Re: Taulman Alloy 910 Profile?
Post by quaver » Sun Sep 04, 2016 1:18 am
I am working on my setup for Alloy 910 as well. I am off to a pretty good start but sill have adjustments to make. Will share when its solid.
quaver
Post by quaver » Mon Sep 05, 2016 9:02 pm
I am impressed with Taulman's Alloy 910. Bed adhesion is excellent; PEI with PVA glue stick, 45°C bed temp. Prints are clean, minimal stringing, virtually no start/stop discontinuities. Printing at 260°C extruder temp with a V3; be advised I have checked my extruder temp with a thermocouple inserted in the heater block temp well and know it runs 8°F cooler than the control set point. I have attached a photo of a turbine wheel printed with these setting. Note that I have not optimized the bridging properties. I am starting with the settings given by jules for PETG.
Taulman_910_Fine.fff
FFF for Taulman Alloy 910, 0.2mm layer height
(9.77 KiB) Downloaded 1119 times
Taulman Alloy 910 at 0.2mm layer height
KaiborgStudios
Post by KaiborgStudios » Sat Sep 10, 2016 1:02 pm
Thanks quaver, I appreciate it!
supportvexma
Post by supportvexma » Tue Jan 02, 2018 7:44 am
Phil
Post by Phil » Wed Jan 03, 2018 6:21 pm
This thread had been a good repository of filament success, (and some failure). viewtopic.php?f=11&t=1951&start=20
Please post to there as well and add any filament not already mentioned that you use.
