'Mammoth' Part Cooler
Hi everyone I'm new to 3D printing, I've been at it for a couple months now and I'm loving my M2. So far I've upgraded it with one of insta's Mic6 plates and that alone had been awesome. Over the past two weeks I've been devising a new design for a blower driven part cooler. After much trial and error I'm ready to present to you my first revision of my new 'mammoth' cooler!
Files for printing:
http://www.thingiverse.com/thing:1886404
Some info:
-- This cooler is printed in 3 parts - main body, tube 1, and tube 2.
-- I used the original makergear fan/hotend connector body to accommodate the main platform for the two 50mm 24v blowers so all credit for that piece goes to makergear. I purchased the 50mm blowers from reprapchampion.com.
-- blowers are wired together and wired into a pigtail cut from the original 50mm cooling fan.
-- I used black hatchbox ABS @ 240c hotend/ 110c build plate, .2mm resolution, .40 extrusion width, .89 extrusion multiplier. (first time ever using ABS, very happy with the result)
-- Printed directly on build plate's PEI surface with no helpers such as glue or slurry. Adhesion was excellent.
--Supports not required on the two tubes if printed with rectangular opening side on build plate, supports are required on the main body.
Pics:
https://flic.kr/p/NYo3SB
https://flic.kr/p/NYo3Sg
https://flic.kr/p/P6NRpi
https://flic.kr/p/NDdbj3
https://flic.kr/p/P6NRkR
https://flic.kr/p/N8BoUk
Files for printing:
Some info:
Pics:
Re: 'Mammoth' Part Cooler
Holy cow! You're gonna blow the print off the plate! (Chuckle!)
That's pretty awesome.
Hey thanks! I have yet to test it. hopefully I'll do a benchy run tonight.Jules wrote:Holy cow! You're gonna blow the print off the plate! (Chuckle!)
3dPrintingMD
That's pretty awesome !
theboz1419
Looks awesome, I wonder though if the height and center of gravity will have an effect on printing in general
Thanks!3dPrintingMD wrote:That's pretty awesome !
Thanks! I have some free time this weekend so I'll be testing it, I didn't get to do a benchy run last night but I'm going to get it running on something right now to see how it preforms. Generally the walls are very thin on the tubes so there isn't much weight there. The main body is semi thick but I went light on the infill to keep weight down while preserving strength - I'll get back to you on how it printstheboz1419 wrote:Looks awesome, I wonder though if the height and center of gravity will have an effect on printing in general
just wanted to let everyone that's interested know that you can now download the files for this cooler at http://www.thingiverse.com/thing:1886404
... how in the hell did you print that? What orientation?
Hey insta, I've been meaning to drop by your thread to tell you how much your PEI MIC6 plate has helped me. This ABS sticks to it perfectly. Actually without that plate I don't know if I could have printed this so easily.insta wrote:... how in the hell did you print that? What orientation?
Anyway to answer your question - I printed this exactly as thingiverse shows when you look at the automatically generated pics where they color the models blue for you.
Just to give an update: after using this part cooler for a few weeks now I couldn't be happier with how it performs. Only thing I plan to work on/ update is the design of the two nozzles that direct the air onto the part. I think there's some room for improvement there.
