I modified the default M2 profile in Simplify3d. Is there a way to reset the profile? I am sure reinstalling would work but was trying to determine if there is another way to get it back.
Thanks
Default M2 Settings
Re: Default M2 Settings
yes keith, in your process where the name of it is...."select profile", click the drop down arrows on the right then choose makergear m2
If you already have the MakerGear M2 profile selected, select a different one at random, and then go back to it. If you have saved your settings as MakerGear M2, you can differentiate the stock settings vs. your exported setting because the stock settings do not have ".fff" in the drop down.
http://jinschoi.github.io/simplify3d-docs/
