M3SE BL Touch Probe Upgrade
Hi All,
I have noticed there is a M3 ID probe upgrade kit available from the Makergear store. Will this upgrade work on the M3 SE? If not, I'm a little curious to know why there is no M3 SE kit available? Thanks.
Re: M3SE BL Touch Probe Upgrade
Someone on the mosaic fb group just bought a M3-SE printer from makergear and it came with the probe attached so it seems that makergear is selling printers with it. Just not sure if its available as a upgrade option. Reach out to makergear and ask them. Mounting plate on ID is different from SE so it might work on SE but you will need to print the belt holder for it
makeal - appreciate you letting me know about the SE with the probe. I will contact Makergear as suggested.
Tried to find some info about it via Google and failed, could you share a response from Makegear if it is possible?
Hi Glen,
I did ask about the compatibility of the ID probe upgrade and unfortunately they are not compatible with the SE. However, they are working on a upgrade for the M3 SE Rev0. That's as much information as I was told, so I am not sure what the upgrade will include.
This sucks. I just received probe upgrade for the SE and it’s a paperweight. I’ll just see it someone wants it on here.
you just need to get a top plate from SE. ID has a different top plate. Try to return it or you can see if you can find the plate and make it work with SE
This is sad, thanks for the information
I'd like to buy one for my M3SE but there's no updates regarding the SE version. Bit disapointing really as it sounded as though it was in the works. I don't know enough to add/modify my M3SE (hardware or software) to take a probe. Has anybody had sucess with adding the ID probe upgrade onto their SE? Cheers.
